Old 05-20-2018, 05:12 PM   #2
itsnotanova
As far as I know all 986 and 996 use the same front. The rear 2.5 and 2.7 are the same but the S has much beefier rear pieces. The stub that the nut screws onto is the same size though. You can put a base axle on a S carrier but you can't put a S axle on a base carrier without some machining of the base carrier
Woody
