Thread: New Wheels
Old 05-18-2018, 01:36 PM   #14
dulmer
dulmer's Avatar
New Wheels
All right, after some blood sweat and tears, the wheels are finally on the car. It turns out that the 18 x 10" wheels do not fit. They come too close to the rear shock tower. I therefore had to use the 18 x 8.5" wheels all the way around. This meant I also had to use 20 mm spacers at the rear. The tires I ended up using were 225/40R18 on the front and 255/35R18 on the rear. The other issue was the centre bore on the wheels was too small. The wheel company sent me another set with the centres bored out larger. Anyway...what do you think? The driver side shows without the spacer and passenger side is with spacer. I went with the spacers.
dulmer is offline   Reply With Quote
