Old 05-15-2018, 10:43 PM   #12
rick3000
There Is No Substitute.
rick3000's Avatar
Glad to hear you got everything sorted out!
Just FYI on the extra coolant they gave you, if you top up make sure to do a 50/50 mix, or just add distilled water. The water is what is conducting the heat, the coolant is just there to keep the water from freezing/expanding/contracting. This was something I didn't know before I worked on the cooling system myself, I thought more coolant was better, that is not the case.
