Thread: start up rattle
Old 05-12-2018, 06:29 AM   #1
dsallean
Originally Posted by Rich XTR View Post
My 2000 boxster s has the cold start up rattle that many have reported. It only does it the first start of the day. I think it is a chain tensioner (all three are new) bleeding down or lifters bleeding down. Can an oil pressure release valve cause this noise? The noise is loud and i would really like to fix it. Verio cam tensioners and pads are also new.
I would like to find a solution to this as well. I have replaced all three chain tensioners and the vario cam tensioners and pads (for other reasons). I have a new oil pressure release valve to install. If anything I think the startup rattle is worse after replacing the tensioners. I also installed a spin on oil filter adapter.
Dave in TX
2001S
dsallean is offline   Reply With Quote
