Old 05-11-2018, 12:45 PM   #10
Geof3
Pretty sure I've seen it mentioned here, to NOT use any detergents in the flush. (maybe search) There are tons of nooks and crannies in these systems, and seems the best advice is to use simple distilled water. Also, unless you vacuum fill the system, you need to know the bleeding/burping procedure to get all the air bubbles out of the system.
