Old 05-09-2018, 05:47 AM   #4
kk2002s
kk2002s's Avatar
Congrats and enjoy your car. Oil and filter are your choice. All good (within reason) as long as you change often. NGK plugs are fine. Lots of folks using Bosch and others as well. Inspect your coils for cracks while doing the job and don't over torque when you put stuff back together!
+1 on above. Don't get lost in the weeds of all the opinions and options out there. Sticking with the OEM speced replacements will work just fine and doing so on a reasonable maintenance schedule
Definitely check those coil packs for cracks. They do crack. I had 3 of 6 cracked under 95k miles.
Check the plug tubes for oil leaking as well. It's all in the same place
You may want to replace your oil filter canister as well as there is a relieve spring in there that can age. Cheap part even though it is a Porsche replacement (My only actual Porsche replacement part)
And let the fun begin
Seal Grey
