Old 05-07-2018, 03:05 PM   #10
xr_guys
Vacuums lines, reseal the oil pan and clean oil pickup line and replaced o-rings. Replace AOS plastic lines and associated o-rings, at this mileage they are all brittle.
Lastly, clean your radiators this is why you have a crack head. Separate the condenser and water cooling radiators and clean the fins. DO NOT use pressure washer, spray water directly and perpendicular to the Radiator, faucet pressure should be good enough.
Did you check if your water line rubber hoses are not oil damage?
Good luck
xr_guys is offline   Reply With Quote
