Old 05-07-2018, 01:55 PM   #4
Grim1ock77
Grim1ock77's Avatar
Originally Posted by Brian in Tucson View Post
You need the proper tool. https://www.amazon.com/4525-Cable-Type-Flexible-Clamp-Pliers/dp/B000F5JM0O
Btw, you can cut those short hoses, replace them with common hose from an auto parts dealer.
The hose clamps are called spring clamps and can all be accessed from the top. When you put the new tank in, figure out where to position the clamps so that they're easier to access.
Wayne Dempsey did a nice write up with pictures. https://www.pelicanparts.com/techarticles/Boxster_Tech/33-WATER-Coolant_Tank/33-WATER-Coolant_Tank.htm
I used the same tool and was able to do this from the top, it can be tricky to get the end just right on the clamp but it is possible.
______________________
1999 Black Boxster
Grim1ock77 is online now   Reply With Quote
