Old 05-03-2018, 05:27 AM   #2
AZ986S
AZ986S's Avatar
Yes great job. Much better line than the Corvette. You catch up in braking and cornering and he should have pointed you by. What tires are you running?
My car has a lot of the same mods you have, except for the 3.6
Does the E Power steering pump make a measurable difference?
How does the car feel? Have you dynoed it yet?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
