Thread: Brake Pad Info
Old 05-01-2018, 07:16 AM   #2
Ciao
Ciao's Avatar
Originally Posted by Anker View Post
When I replaced pads last year a couple of the dampers were stuck in the pistons and broke away from the backing plate, so I decided to do away with the dampers and use brake pad anti-squeal paste instead. Works like a charm. I bought the CRC brand. You smear a layer on the backing plate of the pad and let it dry to a tacky state and then install the pad. Infinitely easier than fighting the dampers.
Sounds like a reasonable solutions;
5280 Cruising @High Altitude
Seal Gray & K&N Filter
