Thread: Brake Pad Info
Old 05-01-2018, 06:09 AM   #1
Anker
Originally Posted by Ciao View Post
No one seems to mention the required use of dampers when changing the brake pads; do we need them? Or is it an option? I understand if you don't change them the brakes will squeal!
When I replaced pads last year a couple of the dampers were stuck in the pistons and broke away from the backing plate, so I decided to do away with the dampers and use brake pad anti-squeal paste instead. Works like a charm. I bought the CRC brand. You smear a layer on the backing plate of the pad and let it dry to a tacky state and then install the pad. Infinitely easier than fighting the dampers.
1941 Dodge Luxury Liner Coupe
