Old 04-29-2018, 03:26 PM   #1
M3Stang
Driver side rear is where the oil cooler is located. (Left of the throttle body)
It may just be the O-rings if there is no intermix. If there is intermix - check your coolant tank for oil and your oil filter cup for coolant - then the cooler itself is probably the problem.
Hopefully nothing worse than that.
Thank you. Where is the best place to inspect this? Hoping to square it away tomorrow.
M3Stang is offline   Reply With Quote
