Old 04-20-2018, 08:37 AM   #22
Geof3
Doug, here is what I would do... double check your oil cooler install. Maybe the one you bought is bad (happens) or, maybe you pinched or even dropped an o-ring. Did you use new O-Rings? While considering the worse case scenario is valid, you are nowhere near having all the facts yet. If, it winds up you have a cracked head, and an entire engine replacement is the way you decide to go (other than fixing) then I would drive it till it dies. Might leave you stranded one day, but then again any car at anytime could as well. It cost me nearly 4 K to put a motor in my daughters old (98) Subaru, I did not do it. You can drop in a motor for not a ton more...
