Old 04-18-2018, 09:49 PM   #2
Cunningr
Cunningr's Avatar
Originally Posted by Booker42 View Post
I live in California and just bought the Top Speed "test" pipes. Called the well respected exhaust shop in the area and he said he cant install them, its illegal to remove even the secondary cats.
There is no way I can burn the existing rusted bolts off without professional help (in more ways than one, ha!)
Any tricks you all could share?
Yeah illegal in cali for sure. Probably wont work but you could try soaking them with wd40 or some type of penetration lube let it sit for a couple of hours, see if that would work.
Look for a not so respectable shop, to cut the bolts for you.
Tell them you need you are installing because you will be tracking the car, so you will be switching in and out. I am sure thats belevable.
Myself have not had them installed, so good luck.
