Old 04-13-2018, 08:24 PM   #2
Doug427
I took the right side bolts off from under the car using a 1/4" drive ratchet, a long extension and a 10mm flex socket. It was an easy job, start to finish at a very relaxed pace less than 2 hours, most of that time was spent draining and adding back the coolant. The actual swap of the pump, from first water pump mounting bolt loosened to last water pump mounting bolt tightened, was probably 20 minutes. The rest of the time was all removing panels, hoses coolant, fan belt, etc. really, nothing to tough about it at all. I bought a 1/4" drive inch lb. torque wrench to get all the bolts torqued properly. It's on the car now, no leaks.
Doug427 is offline   Reply With Quote
