Old 04-06-2018, 11:17 AM   #1
Quadcammer
hmm. From those videos, my gauge definitely feels like its moving more slowly. If I run it up to rpm quickly in a lower gear, it takes a bit for it to catch up, and that doesn't seem to be the case for you guys.
I followed the instructions to a T (16 gauge wire to sender, 14g ground) and a fused power source. The only thing I didn't do is use a dedicated ground, so I'll have to check on that.
I have oil temp on the drivers side, oil pressure on the passengers as I'd assume you guys do also.
My car has always run hot and I'm not sure why, but its also a base car with a 3.2, so maybe a bit less cooling capacity.
Can someone postulate as to what the unmarked lines on the gauges indicate. The one after 200 seems like 210 to me (what my car runs on the street), then 240?
