Old 04-04-2018, 02:25 PM   #1
AZ986S
AZ986S's Avatar
Yes, sorry that I forgot to post. We added another 0.5° of negative camber front and back. So -1.5° front and -2.5° rear.
I have the same setup (plus Eibach swaybars), just an additional 0.5 deg negative camber in front (to -2.0-2.1) since I slotted my towers. Had to get rear adj toe links to get toe correct. IMO, running my Federal RSR595 RComps on stock staggered 17in Boxster wheels, the car is very well balanced for the type of driving and tracks I see. If I were running full slicks, I would probably need more negative camber in the front.
I don't know what tires your run, but you'll be happy with this set up, definitely not too much oversteer.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
