Old 04-03-2018, 09:54 PM   #1
Geof3
Originally Posted by dav9515 View Post
what is the service life of a flywheel in the 986? i get the "while your in there" theory, but shouldn't the flywheel be fine after 75k? i would think it should last double that at least.
just thinking if the clutches last about 75k miles then the flywheel can be changed with the next clutch job, upon passing inspection of course.
Remember one thing, yes the car only has 75k on it, but is still 14yrs old. Given rubber gets pretty funky with heat cycles and age, you wouldn’t want to replace all of the other components, then have your flywheel fail at some point. Mine is an 02 and when I have to do a clutch, the entire thing will get done... piece of mind, and time/mileage reset to zero on all of those components.
