Old 04-02-2018, 06:41 AM   #18
Quadcammer
Originally Posted by Anker View Post
Reviving an old thread.
Having the 986 S out of winter storage I decided to check the warm up time to full engine temperature (needle covering the 8 in 180). 40 degrees F and suburbian roads with little traffic, max speed 45 mph.
At 5 minutes the needle was between the second and third line, the third being the 180 degree line. At 6 minutes the engine was up to full operating temperature.
At higher ambient temperatures and/or higher speeds the temperature would have risen faster.
If you run a low temperature thermostat in the mistaken belief that it will reduce engine overheating (see Low Temp Thermostats: What’s the Advantage? | Tuner University), then the warm-up temperature will be longer and engine wear will be higher.
Oh boy. First, your coolant gauge is absolutely useless. 2nd, do some research about low temp thermostats on these cars before making such comments.
