Old 03-31-2018, 06:54 PM   #14
986bsdriver
Hate to bring this thread back from the dead. I found some 18x11 rims with a 45 offset and 18x8 with 50 offset. Pretty sure the fronts will fit without an issue. The rears is why I’m bumping this thread.
From what I got out of this thread is that I will be needing a minimum of a 13mm spacer so it won’t kiss the struts in the back. When I use a spacer of that size, will I also need to buy extended wheel bolts to accommodate the spacers? Same goes with if I were to use the 5mm spacers they come with for the front as well?
986bsdriver is offline   Reply With Quote
