Old 03-25-2018, 10:41 AM   #2
BYprodriver
BYprodriver's Avatar
Originally Posted by drewmarc View Post
Ok, update, now i feel stupid haha There is a leak underneath the car in the rear area. I would say that it is underneath middle of the car in between the two rear tires. It is definitely the new Brake fluid I had put in yesterday. The brake reservoir is lower than yesterday as well. I am thinking its the slave. Thoughts?
I'm sure it is the clutch slave cylinder leaking fluid, you may be able to replace the rubber seal onto the cylinder, but if it has a lot of miles, (50K+) you should probably replace it while you are in there. Be sure to read up on this whole procedure on Pelican parts .com tech info section 1st.
