Thread: Stereo issues
Old 03-22-2018, 11:54 AM   #11
Cunningr
Cunningr's Avatar
Originally Posted by Stiles13 View Post
Yes all connection are good, and I used the RCAs. The system was only playing 1 channel out of for BEFORE the install as well as after. I hoped it was the head unit, but apparently it is the amp. I'm seeing used ones on Ebay for cheap, so I may take that route instead of dissecting the output side of the amp harness. will ohm out speakers first to eliminate the possibility of 3 blown speakers. The RCA wiring from the amp harness appears ok.
Yeah i bought a 2 channel amp for $20. I am taking out the plugs and fabricating a factory to aftermarket amp interface. If you go back stock get a 6 channel from a cabriolet if you dont have rear speakers you can use the fad to adjust door speakers.
The door soeakers only play bass by the way.
If you do go with a 6 channel you may need to trim a key off the amp so the plug will fit. There us a thread about that some where.
