Thread: Stereo issues
Old 03-22-2018, 11:00 AM   #10
Stiles13
Originally Posted by Cunningr View Post
I take it you have a factory 4 channel amp?
Asuming all you did was replace hu and used an adptor kit you should check your wiring connections again.
For the factory amp you need to use rca out of hu, the factoryamp wont take line level input signal.
I am in the process of doing a complete ugrade, myself. I tried 5he 6 channl amp route and is ok, and easy mod but better off with complete system upgrade.
Yes all connection are good, and I used the RCAs. The system was only playing 1 channel out of for BEFORE the install as well as after. I hoped it was the head unit, but apparently it is the amp. I'm seeing used ones on Ebay for cheap, so I may take that route instead of dissecting the output side of the amp harness. will ohm out speakers first to eliminate the possibility of 3 blown speakers. The RCA wiring from the amp harness appears ok.
Stiles13 is offline   Reply With Quote
