Thread: Coolant Loss
Old 04-29-2004, 09:23 PM   #1
mcd
on my 97 a week after purchase,a simalar thing happened. i pulled into garage ,lifted on rack found out water pump had failed. where the serpintene belt goes around the water pump if yours is bad that pulley will move quite alot. i replaced this part myself with minimal problems. if this is infact the problem feel free to e mail me i will be glad to hook up by phone and help if you want,if you do your self make sure the bolts all go back exactly where you took them from , some are different lenghts. hope this helps someone good luck.also there is a bleeder directly under the plastic where oil fill and radiatorfill are in rear trunk.lots of luck agian MCD
mcd is offline   Reply With Quote
