Old 03-21-2018, 01:29 PM   #11
SoloPierre
Since you want 2 degrees in front, looks like you need a 10,6, and 3. This is per a side. You can fine tune with the strut slots on the top. Most likely range from 1.5 to 2.25 playing with the slots.
Not sure what rules you are playing by.... you can also mod the factory strut tops for more camber. Just redrill the 3 holes and remount the bolts. Shave the corner of the factory strut top that hits the inner fender well. Costs nothing. Won’t get you 2 degrees at factory height and no arms, but it’s a step in the right direction.
SoloPierre is offline   Reply With Quote
