Old 03-14-2018, 11:12 AM   #1
speedyspaghetti
The track arm can be checked easily. Just jack up the front end and put on jack stands, remove the plastic brake cooler, remove the track arm bolt to the control arm center bushing and swing the track arm forward. You can then check for play. If yours is bad enough to "clunk" you will easily feel it. You can then visually check the center bushing in the control arm. Stick a large screwdriver thru it and move around looking for cracks or tearing. If no play then just bolt back up. no alignment required. You sure the clunk you're hearing isn't just due to play in the steering wheel lock side to side?
I'll double check, but I'm pretty sure I would hear it on the passenger side as well if it were the steering lock, no? I'll do the control arm test when I get a chance later this week - I was also alone this week so I'll have a friend wobble the wheel while I get under the car - I wasn't able to see much of anything by myself.
speedyspaghetti is offline   Reply With Quote
