Old 03-13-2018, 02:22 AM   #1
key_lime
key_lime's Avatar
Originally Posted by Stiles13 View Post
In removing my AOS on my 2001 Boxter, I cracked the flexible part of the oil fill tube. how do you access the clamp that holds it to the fill tube in the trunk?
I found this tricky too - In the end I managed to get at it with a pair of needle nosed mole grips, and a lot of patience
Here's an action shot
If you have a secondary air pump, you will need to remove it - I'm not sure how easy that is, as my car didn't have one
Getting the new hose on was also quite challenging - I used a good quality pair of locking flexible hose clamp pliers to hold the spring clamps open while I located each end, then released. You need to take a lot of care doing this, as the fill tube on the engine side is ridiculously fragile, and will break if you put too much force on it (I broke mine)
key_lime is offline   Reply With Quote
