Old 08-31-2006, 04:38 AM   #2
RandallNeighbour
I have installed them successfully.
You MUST remove your cluster to do it right or bad things happen like superglue on your plastic faces, etc. If you try to do it with the cluster in the dash it will be a mess that can't be reversed.
Basically, you take thick superglue and put a thin bead around the inside of the trim ring or brush it on and then lift it straight up and into place on the inverted gauge cluster. The dials are pointed down to the table on which you are working.
