Thread: Short Shift kit
Old 03-09-2018, 08:03 PM   #1
Geof3
Originally Posted by rp17 View Post
What are you guys using to disconnect the cables from the shifter? Pry bar?
Oh, heck no. The shifter cable goes into the shifter very easily. The retaining portion is spring loaded and simply twists and pulls back from the cables and the end lifts out. If I recall they lock into that position as well. Mark your cable position at the shifter. The cables connect to the shifter housing with a clip. Pretty straight forward.
