Thread: Short Shift kit
Old 03-08-2018, 03:29 PM   #10
Geof3
Once all of the screws are out, the actual pulling out the console is a little fiddly, as it putting it back in. Now is a good time to get rid of the lousy "rubber" paint and refinish your console as well. The install of the shifter is very straight forward... While you are there is it also worthwhile to take a look at your cables on the trans end. They are prone to wearing out at the ball/heim joint and a short shifter will only exacerbate an issue if there is one. Easy to check but the rear end needs to come off the ground...
