Old 03-06-2018, 06:09 AM   #7
Brian in Tucson
Originally Posted by Stiles13 View Post
Can you please share the vacuum diagram?
you bet! Click the thumbnail:
A. I don't recall what it's called.
B. Vacuum tap on the left side of the front plenum.
C. Fuel pressure regulator.
D, E, F. Vacuum reservoir, junction, and diaphramed fitting in front of the AOS
G. Three way junction on manual trans cars, 4 way junction on Tip. with the additional hose going back to an electric vacuum switch for the trans coolant control
H. Vacuum check valve. Must be attached in that particular orientation.
I. Three way junction.
J. Electric vacuum control switch.
K. Resonance Valve on left bottom of the front crossover.
L. Vacuum source on the front, left crossover boot.
I don't recall where I got this diagram. I did not do the original work, tho.
2001 Boxster
2007 Toyota Highlander
