Old 03-06-2018, 05:15 AM   #11
Quadcammer
Originally Posted by Stiles13 View Post
Brian, do you know which way to disconnect the end that goes to the front? I can't fit my hand through from behind the seat, and the air filter housing blocks the other direction. Any tips would be greatly appreciated.
see if you can get to it from under the car. I recall being able to reach it from below.
Also helps if you have a friend who can push/pull on the hose while you pinch the fitting.
