Great thread!
Nice to see that others than me are trying to get good audio in the Boxster!
I am currently installing a similar system in my Boxster..
Hertz Mille pro 70.3 and tweeters in the dashboard and Hertz Mille pro mpk 165 6.5" in the doors.
Also a pioneer HU in network mode, but since the 6,5 in the doors needs to have a crossover setting for ca 250hz they need to be in stereo, so I am running the mid and high in the dashboard from four channels of one amp, and the doorspeakers from a separate 2 channel amp.
Have started tweaking a bit and personally I need more bottom fill in low hz so next step will be to rebuilding the bose enclosure on the shelf for two flat 8" subwoofers which will also be driven of a separat amp.
Have also installed a backup camera.. you too?
Have inserted quite a bit dampening in the doors and dashboard, and the door speaker enclosures, but the sound will never be good when driving so my goal is to not fokus on ambient/highway/road sounds but just on interior rattle and speaker invironment when car is standing still.
Still got some static noise from the car both with motor running and not.. you too?
