			Well, it’s certainly doable. You might take dsallean’s suggestion and drop it a wee bit. Dropping the engine a few inches is easy as you don’t have to remove or undo a lot of stuff. This would also give you more room to install the larger airbox. That way you could avoid some of the problems that I had when I installed my 987 air intake system (see my airbox install videos in the diy section of this forum).
