Old 02-28-2018, 07:53 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
It snaps in place. The plastic that is part of the top is much stronger than the plastic tabs on the covers, so the covers will break first. I have installed/removed mine at least two dozen times over the last ten years with no issue other than some of the tabs on the cover bending, and I just bent them back. I may have replaced the latch cover once in that time, but I cannot recall. You can buy the rear covers as well, check the parts manual pdf for the part numbers. They are simply a cosmetic item.
