Old 02-23-2018, 01:25 PM   #29
gabedrummin
gabedrummin's Avatar
This is why I do as much work on the car my self .This cars are expensive to keep on the Road. Nothing more expensive than a cheap Porsche. Had a starting issue .Some times car would not start . Didn't matter if car was hot cold tired or ready to go sometimes it wound not crank. Then 30 seconds later it would start . The worst time 45 mins. Tow truck on the way she firs up. Replaced the battery ,ignition switch.The steering lock. Relays . clutch swith. When I finally got fed up took it to Porsche they said short in starter.1800.00 bucks and a hole in my top later.car starts every time.Now she decides to have low oil pressure at idle.These are expensive to maintain.Do as much as you can yourself.
gabedrummin is offline   Reply With Quote
