Old 02-20-2018, 09:43 PM   #1
Cunningr
Cunningr's Avatar
Smile
Here's the diagram of the 2000 model amp wiring:
(click to link to higher resolution)
Thank you this helps. 1 question pin 7 looks like it is switched 12v to me. Is that correct? That can be used to turn on amp. I will probably just run rca cables for inputs but this gets me into a switch 12v and factory speaker distrobution without cutting up any thing.
I found some class d micro amps i may use. Swapping in tang 5.25 subs into doors, i bought some used boxes to cut up. I dont see fitting 8” subs likee i wanted.
Anyway thanks.
