Old 02-20-2018, 06:21 AM   #12
cas951
Originally Posted by lowpue View Post
It takes forever...like 10 minutes for the engine to warm up to operating temperature. I am assuming that means the thermostat is stuck open...Any other possibility? I want to go in to repair knowing all options to fix. Also, Thermostat should be easy job, correct?
5-10 min is not abnormal at all to reach normal operating temperature. If your thermostat is stuck in the open or partially open position your engine temperature may not reach normal operating temperature specially while driving at speed. Observe your engine temperature while the car is moving versus while the car is at a stop. If your engine temperature rises while at idle and the engine temperature decrease while moving is a good sign the thermostat is stuck open or partially open.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
