Thread: DME rev report
Old 02-19-2018, 11:35 AM   #1
Anker
Range 1 is not an issue, the car was built for that and the fuel cutoff prevents the revs from going higher.
Range 2 is bad. Usually happens when you downshift at high revs. When you release the clutch the transmission pulls the revs above the red line. Even 20 crank revolutions can fatally damage the engine. I was in a DE last year when a Cayman inadvertently downshifted to second instead of upshifting to fourth. Less than 20 crank revolutions, but the engine was toast!
1941 Dodge Luxury Liner Coupe
