Old 02-16-2018, 08:34 AM   #13
Starter986
1998 Boxster Silver/Red
i'd love to get rid of that hose. impossible to get at, gets brittle, and is in the way of a lot of tasks on the engine - pretty much anything that requires moving the intake. and, with my ac, sai, and ps off the engine, it is the last piece of clutter. i've often thought of fabricating a replacement. doing as start says must be possible, as it is often done with with the shorter aos hose to the intake.
You know... specifically I was going to quiz you on my inquiry... but somehow I knew you'd chime in. I'm glad you did.
Since you've had the intake, sai and ps out... did never you say to yourself "I'm going to employ silicone/rubber."? Do you believe that it could be done with silicone/rubber tube/hose? isn't there an alternative to the hard line? Would it be terribly difficult to affix the new silicone/rubber to the connecting ends (once they've been sawed off the hard tube)?
Thank you.
1998 Porsche Boxster
