Old 02-14-2018, 03:07 PM   #1
Gilles
Originally Posted by Josephjochoa View Post
I have an 02 Boxster S tiptronic. I cracked the lower AOS breather hose as well when installing new AOS. . It was brittle from heat and age. How did you get the new lower hose on? I have a new one but can’t even snake it in on the drivers side. Once one side is in how would you get in the other? Did you remove everything on top including the plenum? I’ve removed both cross tubes but still can’t get it in. Has anyone replaced this breather line with something more flexible like heat shielded rubber or silicone hose?
Hola Jose,
If you remove the engine access cover behind the seats you will have more room (and you will be able to see what are you doing..), that way you don't have to remove the intake plenum.
Good luck!
