Old 08-28-2006, 03:20 PM   #3
MNBoxster
Originally Posted by idjiot
I noticed that my car has a weird "flapping" noise coming out of the A/C vents when I turn them on - I believe this only happens when it is really hot - which explains why the A/C is on.
Anyhow, if I lower the speed of the fan manually - I usually just push the auto button - and then let it go for a few minutes and then push it back up, the noise usually goes away.
Has anyone experienced something similar? Is there any way for me to figure out what's causin this problem without opening up the entire thing?
It doesn't seem like a big deal but I guess it's a tad annoying.
Hi,
I can't tell specifically, but since it's Fan speed dependent, wonder if it's not a bearing in the blower motor. When these start to go, they can often be made to quiet by doing exactly as you describe. If I'm correct, it won't be long before you won't be able to make it stop and then you're replacing the motor (or the bearing if replaceable, probably not). Hope this helps...
Happy Motoring!... Jim'99
