Old 02-11-2018, 10:13 AM   #25
SC-986
SC-986's Avatar
I'm a fan of the "AirLift" system. Replaced the WP, T-stat, and engine mount on my '02 base a couple of years ago. After watching a few YouTube tutorials on use of the "AirLift" system it was easy peasy. Used a 6 gal. pancake compressor to draw vacuum.
I like the fact that you can verify the integrity of the cooling system based on whether or not it holds vacuum. If there is a problem you can recheck your work prior to re-filling the system. Saves a lot of time in potential rework and you can refill the system in no time with no worries of air in the system.
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
SC-986 is offline   Reply With Quote
