Old 02-06-2018, 04:54 PM   #10
AZ986S
AZ986S's Avatar
Originally Posted by gabedrummin View Post
Put in the updated spring and piston .Put a mechanical gauge on it today 10 psi when motor is hot with 5w-40 oil. What would be the thickest oil I could run .Live in the south west.
Sounds a little low to me but isn't the pressure switch set at 7 psi?
If it were me, I would try a heavier oil, Mobil 1 5W50 or 15W50. 5W50 is Porsche approved in our cars. You'll most likely get a couple (2-3 psi) more at hot idle. How about the oil filter? What is your setup? Stock or aftermarket?
Walmart has Mobil 1 15W50 on special for $27 for 5 quarts.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
