Old 01-31-2018, 12:03 PM   #1
particlewave
The passenger and driver side are not interchangeable. Before replacing the door latch, check the connector in the door jamb. Pull back the rubber boot, remove one torx screw and pull the cam lock release. A search should pull up instructions with pictures.
Check both male and female sides of the connector for corrosion or other faults.
It would also be good idea to check under the seat for moisture and pull the immobilizer to check for any corrosion from moisture/water infiltration.
Once you've confirmed all is good, replace the door latch mechanism.
particlewave is online now   Reply With Quote
