Old 01-25-2018, 02:12 PM   #1
BobRickel
BobRickel's Avatar
I have the same problem on my 1997 Boxster drivers door. I replaced the window regulator and properly adjusted the window. I replaced the door latch mechanism. It did not cure the problem. When I pull on either the inside or outside handle and open the door the interior lights go on but when I let go of either handle the window pops back up. I know the micro switches are working on both handles and the latch switch is working because the interior lights come on when the door is opened and go off when the door is closed. I end up partially pulling up either the inside or outside handle to index the window open as I close the door then let go of the handle to fully close the window again. Any Ideas would be appreciated.
BobRickel is offline   Reply With Quote
