Old 01-21-2018, 12:40 AM   #7
jimk04
I installed guages and an X51 sump.
The guages were a royal pita to wire and sort. Access is a nightmare! I used a 996 sender in stock location and the temp sensor in the other head. I believe the temp reads hot do to reading from the head.
A very informed member on Rennlist has done exhaustive research into the oiling system and has designed and built a very nice dry sump system. He tested all known sumps and in his words he wouldn't recommend the x51 sump in a mid engined application....
Mine is still in for the record
jimk04 is offline   Reply With Quote
