Old 08-25-2006, 02:49 PM   #11
MNBoxster
Originally Posted by CJ_Boxster
So, say i were to just have porsche activate the OBC...but not install the switch, Would the OBC display the outside air temp by default...i just wouldnt be able to scroll through other modes???? Would this be correct?
Hi,
Yes you are correct. If you have the Temp sender (and it sounds as if you do), then the Dealer can turn on the OBC and you'll get the outside temp and no other functions will be accessible or controllable without the combo switch w/ 4th stalk. Hope this helps...
Happy Motoring!... Jim'99
