Thread: Milky coolant.
Old 01-16-2018, 12:41 PM   #1
jb92563
jb92563's Avatar
The coolant should not be going anywhere unless there is a leak externally or internally.
The oil consumption should not be much either in a issue free engine, less than a quart in 5K miles of driving.
A cooling system pressure test would be a good inexpensive way to start the diagnostics.
Hopefully its not a cracked head which would send oil and water through the engine at those kind of rates.
Not sure is a Head gasket could be the issue, not familiar with that part of the engine, but a cheaper fix than cracked.
