Old 01-11-2018, 10:44 AM   #1
911monty
911monty's Avatar
Since you said tyre shop instead of tire shop I assume you are on another continent and car is right hand drive. If so then relax. The coolant expansion tank overflows in that vicinity. What you need to do is check your coolant cap and see if the part number ends in .04. If not replace the cap, refill and purge the system.
The coolant light flashes when the tank level is low. And the countdown timer is increased due to the car not being at temp when SD.
Also forgot to say.....The coolant cap is stupid easy to install incorrectly. Works best to turn backwards until cap drops as threads engage then tighten. I also see the speaker confirming RHD.
